Why did you buy the most powerful diesel variant, only to want to reduce the power for a bit more economy?
I can imaging the break even point being very lengthy. A 1.9 golf will still be doing 40-50mpg, I don't see how you can reasonably expect to improve that in a meaningful way? If you can't afford to fuel it then spending money on remaps might not be a good investment. If you can afford it but just fancy improving it then leave it well alone
Fail to understand what he is aiming for.
An economy remap doesn't reduce the factory power. You still get more power, but a more efficient map.
My Alhambra has an "economy" map on it. Well, it isn't really, there were 3 map options where I got mine done. Economy, Balanced and Fast. I'm sure most people plump for the fast one, I went for the balanced one. Didn't do much for economy mind you, maybe 1-2 mpg better overall, around 3-4 mpg better on a run. But it is noticeably faster now, which is nice.
My old A3 2.0 TDI 140 had switchable maps. I ran the economy map for about a year, and gained around 4-5 mpg out of it. I then replaced the clutch / flywheel and banged the fast road map on it. Economy was back to normal levels, but again, a noticeable increase in performance. In a straight line, it was almost as fast as my Golf V6 4Motion I had at the same time.
Go to R-Tech
This. It'll be the best option, and you'll get a custom map to your requirements.
It's likely to be getting more motorway mileage than was anticipated when I bought it. The "Green" variant of the remap they do enables you to cruise at 70mph at a lower rpm, so is meant to save a fair bit. What the savings are is what I'm hoping someone has experiences with.
I did see some gains, but don't expect massive gains in economy. It will still take a while to pay for itself. But it will be a more enjoyable drive that whole time. Be mindful that you may well need a new clutch / flywheel after though. I have the coin in the bank for the Alhambra needing it done.
