as title.
i may well change my cpu soonish, the one i have is a winnie, and has done superbly 2700~ish (not stable
) but i had some bother with my water pump, and it'd shut down a few times due to heat, and now i have another pump the poor winnie doesn't like an OC at all, and i mean at all, if i raise the fsb just 5 it flids, so i just run it at std speed.
i did rma my ram a while ago patriot TCCD and haven't oc'ed that ram, so maybe it could be that but i don't think so.
stuff :
water cooled rig
neo2
3200 winnie
2x512 patriot tccd
i haven't oc'ed since the rma and then i had the pump pack up, but before then i was getting REAL good results from the stuff.
your thoughts?
as i'm assuming it's the cpu i would replace it soon, so whats the best 939 for oc'ing these days opteron, san diago, venice + the best codes on the chips
, i intend to get oc'ing again!
) but i had some bother with my water pump, and it'd shut down a few times due to heat, and now i have another pump the poor winnie doesn't like an OC at all, and i mean at all, if i raise the fsb just 5 it flids, so i just run it at std speed.i did rma my ram a while ago patriot TCCD and haven't oc'ed that ram, so maybe it could be that but i don't think so.
stuff :
water cooled rig
neo2
3200 winnie
2x512 patriot tccd
your thoughts?
