Specifically MySQL. I have the following table:
This records a score for a user, one score per day. I want to aggregate the score for each user but only show a specific users aggregated score, the 5 users with a next higher score and the five users with the next lower scores, so 11 records in total. In other words it will be a segment of total scores around a specific users score, including the use.
Edit: I'll post my query, which now works but I'm still after a simpler solution:
Does anyone have a nice simple query that would drag this information out, without using a page long query that seems to be a sledgehammer to crack a nut? Been looking at this too long now and can't see the wood for the trees.
Code:
CREATE TABLE IF NOT EXISTS `Scores` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`userid` int(11) NOT NULL,
`datedone` date NOT NULL,
`score` int(11) NOT NULL,
`timetaken` int(11) NOT NULL,
`latitude` float NOT NULL,
`longitude` float NOT NULL,
PRIMARY KEY (`id`)
Code:
/*set the userid of the score queried*/
set @userid=10;
/*get that users total score for year*/
set @score=(
select sum(score)
from Scores
where year(datedone)=year(now()) and userid=@userid
/*order the record set by the total score*/
select * from(
/*get upper range*/
(select userid,total from (
select userid,sum(score) as total
from Scores
group by userid) as subq1
where total>@score
order by total asc
limit 0,5)
union
/*get lower range*/
from Scores
group by userid) as subq2
where total<@score
order by total desc
limit 0,5)
union
/*get users record*/
(select userid,sum(score) as total
from Scores
where year(datedone)=year(now()) and userid=@userid)
) as subq3
order by total desc;
