Query regarding the Alphacool VPP655 Pump
Man of Honour
8 Nov 2007
Outer Space
Hi all,
Does anyone know if the Alphacool VPP655 is a true D5 pump or is it one of the cheaper Chinese clones that some companies are selling?
Hi all,
Hi check back made in Hungry/EU? 37watts and looking at them it's the 755 that is made in China.
The 655 single speed which runs @ 4 is lower power rating draw and the Aquacomputer ones are the same
According to the photo of the back, it's made in the EU and 37W, so that's a genuine D5?
Hi yes should be unless someone is being dubious! But the VPP655 and 644 are D5's 644 is single speed version Them Aquacomputer.EK/Thermaltrout and some others are all D5 just dressed differently!
I have one and it seems to be a proper D5 vario (mines the non pwm version). Mine is sitting on a piece of foam running at full speed and is completely silent. It was a very pleasant surprise after being used to the whine of my old Aquaextreme 50z's.
