Quesion About SpeedFan?
15 Oct 2007
Bedfordshire, UK.
Just put together my new build
Abit IP35 Pro
Q6600
Thermalright Ultra-120 Extreme CPU Cooler
4Gb Geil Ram
8800GTX
and before starting to over clock i wanted to make sure my cpu and hearsink were seat and the thermal paste was applied correctly. So i ran SpeedFan, i noticed the following Core temps:
Core 0 = 18c
Core 1 = 14c
Core 2 = 9c
Core 3 = 9c
Now im guess this is usual for just browsing the web for cores 2 & 3 to be cold?? I have now had 2 copies of Go Sp2004 running for around 8 minutes and im getting the following temps:
Core 0 = 29
Core 1 = 25
Core 2 = 24
Core 3 = 24
Is this reasonable? should the core temps be so different?
I think the coldest your cpu can get is the temperature of the room that you are in, so unless your in a 9degree room, I dont think it is right.
Cant seem to get that to work, says the driver has failed to load, so info shall not be avaliable
Yeah Vista, ok have used the vista version of Core temp, and now after 12 minutes of running Prime95 my temps are:
Core 0 = 56
Core 1 = 52
Core 2 = 48
Core 3 = 48
These temps seem quite high to me, seeing as the cpu is running at stock 2.40??
Core 0 = 56
Core 1 = 52
Core 2 = 48
Core 3 = 48
Seems about right, quite a large difference in temperatures though. Probably an unflat IHS.
Whats regarded as unsafe difference in temps between cores? Is it worth reapplying the thermal paste, i used the clinfilm over the finger trick to apply the paste, maybe i should have added more? I have now OC my cpu to 3.2 and 1.4volts, temps after 25 minutes are
Core 0 = 68
Core 1 = 67
Core 2 = 61
Core 3 = 61
So looking at them theres a 7c difference between the cores
What version CPU are you using, G0 or B3 stepping!
When installing the Thermal paste if your using Arctic Silver you only need a thin line across the center and the heatsink will spread the compound.
Rob
