- 12 May 2011
- Southampton
My Quest 2 cable doesn't seem to connect reliably so I am looking at using the air link instead.
From having a little play it seems that I can't connect ad-hoc to my computer's wifi adapter, it will always be via the "router"?
I have a (cheap) wifi extender thing and I connected both my PC and the Quest 2 to the _EXT wifi network and it is a suspiciously good connection on the quest 2. The PC is connecting to the extender via Wi-Fi 4 (802.11n) with a speed of 144/144 (Mbps) over 2.4GHz lol.
However this appears in-headset to be a suspiciously good connection. Do you know if this connection will be going from "PC - extender - headset" or will it be going "PC - extender - modem+router - extender - Quest 2"?
