Quest 2 problem (mark on lens)
24 Feb 2003
Porthcawl and Southampton
I’m selling a Quest 2. Don’t know much about them.
On the left lens there’s a little mark which results in a soft patch, off axis in the field of view. Because it’s off axis, it doesn’t hinder anything really.
The problem is, I’ve got to mention it and I’m sure it’s putting people off.
Is there anything I can do about it? Are the lenses replaceable and would it be worth it?
Unfortunately the lenses aren't replaceable. Any attempt to 'fix' the issue (e.g. using abrasives like polywatch to polish it out) risks making the problem worse.
Thanks mate. Appreciate that. At least I know there’s nothing I can do and should just leave it. It barely affects the experience anyway.
