Quest 3 + Asetto Corsa + 4070 Super
26 Apr 2024
Brighton
Hi guys!
I'm putting together a computer with a 4070 Super and I'm planning to use it for Asseto Corsa with a Quest 3.
I was wondering if anyone has the same or similar setup and could give me advice on setting it up to the best I can get from the 4070.
Thank you in advance!
Amazing thank you!
Does it works well with the 3070??
Thank you for replying
To a certain extent, I have messed around for hours and still can't quite get it to where I want it but I think it's just the limitation of my 3070. It's more than playable but just hard to keep the frames from dropping. Also when playing online with online / traffic I have to turn things down further. I would recommend having two graphics configs, one for offline single player time trials etc and one for larger online servers. I have also had more luck with the quest link software over "Virtual Desktop" too.
Thank you! I'll give him a follow and watch his video
Im using my Quest 3, Assetto Corsa and a 4070 super and have no issues at all. Quality and framerate is spot on. I only play at 72hz as i find it more than enough for myself, although
some people need 90+ so im not sure how the performance is with this.
Amazing! Good to know! I was told the 4070 super may not be enough for it... I'm sure it is plenty to run VR but just wanted to check.
I'll be probably using it next week if I have it all ready.
Any advice on setting or where to look?
Thank you!
4070 super is more than enough, I played it on my 2070 super and it was fine on that.
I use content manager and have all my settings in there. I'll post them later if your using content manager
OP I ran AC fine on a 3080ti fwiw. Not sure if the these are still compatible as it's been a while since I played it, once your comfortable with getting it all working check out FHolgers FSR mod and Open XR Toolkit as they both mess with the resolution + provide foveated rendering to give more FPS.
I'll look at that thanks
