- 7 Sep 2014
Just been experimenting with the Spatiality app on Apple TestFlight. It allows the 3D Spacial video recorded on the iPhone 15 pro and max to be played on any 3D device.
It converts the Spacial data into a standard 3D side by side or 3 top bottom. Only takes a few seconds to convert the video
For 1080p per side the results are good (better than the Quest 3s 3D recording)
So if you are into video and have compatible iPhone I really would give this a go
