Quest-Quest PC-Quest Steam
18 Oct 2002
My Room
Hello,
Is there a difference between Quest App PC and Quest with Steam PCVR
This is probably a simple question with a simple answer.. but so you know what i mean: (because I don't really know the best or official way to call the different methods)
Quest standalone - is what it is
Quest App PC - Have the game on the quest store but is installed on PC in the quest link app thing and connected with cable
Steam PCVR - Game on steam and play on to the quest connected with cable
Is there a difference between the two PC versions, is one better than the other?
Thanks
Steam Vr and Meta PC app versions are both PCVR and generally will have better graphics than the native headset version.
Many of the Meta Store apps are crossbuy (e.g if you buy the Quest 3 version you also get the PCVR version)
However if you buy on steam you won't get the Quest 3 headset version.
