Question about 12V PCIe motherboard socket use
11 May 2007
I'm thinking of getting a GA-P35-DS4. Do i only need to plug a cable into the PCIe 12V motherboard socket if I am running more than one graphics card?
The GA-P35-DS4 manual states "when you install 2 cards connect the power cable from the power supply to this connector"
This suggests that it isn't needed even if you are running a top of the range card is that right?
Thanks
