Hey guys.
Im looking to get a new case as the one I got now only has a fan at the back and 1 at the front, it does have 2 slots at the top however there would be nowhere to plug them in, and I'd like to see a bit lower temps with my GPU aswell (Twin Frozr2 GTX 560) as the twin frozr design, apparently, dumps the hot air into the case.
So I looked a bit, and found this: http://www.overclockers.co.uk/showproduct.php?prodid=CA-221-CM&groupid=701&catid=7&subcat=29
Just how good is the case ? Also looking to fit in a titan fenrir evo CPU cooler on my Phenom aswell.
Also, in the description of the case, the fans and 'Optional' choices are confusing there. Which fans and where would definitely come with the case ? I got a bit confused there with the wording Optional, and I thought I'd have to pay for all the fans lol ?
Thanks in advance
Thanks in advance
