- 10 Sep 2014
- Azaroth
Hi all. Well I went and bought an oc tech labs 360 aio kit from overclockers uk using Grizzly Hydronaut and 3 Noiseblocker Silent Pro 120 mm fans.
I started up real temp and after my system had booted reset the temps. I have put a picture of the temps in the spoiler.
Should I be worried that 2 of the cores hit over 50 when the system was idel? Started to play ac origins and the temps in afterburner go to about 60-65c after one hour of gaming but the peak temps on 2 cores are 77.
My h100i I had before had lower max's when idel. When gaming it was a little bit higher 63-67c.I had 2 240 notcutra 1500 fans on the h110. Anyone with experience with a 360 aio? Are the temps I am getting what would be expected? I am running the 8770k at 5 gig with 1.25 voltage. Was hoping the 360 aio would lower the temps enough for me to push to 5.2 with a 1.35 but when I tried that the core temps in ac were in the 75c range. Any help would be much appreciated
