NathanE said:http://en.wikipedia.org/wiki/Acpi
If you're running Vista then I would recommend you set it to ACPI 3.0 because Vista (unlike XP) can actually take advantage of this.
NathanE said:If you've already installed Vista then I don't recommend changing it. These are the types of BIOS settings that should be set before installing the OS.
If I'm too late to mention this then I hope it doesn't mess up!![]()
NathanE said:Good good. There's not really anything to "check" per se. Vista supports it so why not use it?![]()
