Hi,
I recently applied AS5 to my E6550 and plonked on the Akasa AK-965 Heatsink and Fan. It is a triple copper heatpipe with Aluminum fins and 90mm fan.
At the stage, after about 4 days after application of the AS5, temps at full load are hitting 60 degrees C+
On a 2.9ghz overclock, full load is way too hot, hitting as high as 80 degrees, so that has been backed back down to standard. Shame as it was looking good on a very brief Orthos stress test.
Should the AS5 start to make a difference in a few more days? I am seriously thinking of a new Cooler for the CPU but there isn't much clearance from the CPU socket and the Northbridge Heatsink. The mobo is an Abit FP-IN9 SLi nForce 650. (http://overclockers.co.uk/showproduct.php?prodid=MB-124-AB).
What compact coolers are recommended if it is to be replaced, or is it worth getting some cleaner, cleaning the cpu and fan and re-seating it with new AS5?
Not sure if part of the problem is down to the push pin clips on the cooler. They don't seem to be the most secure in the world.
Any suggestions would be welcome. I just want to get this new rig right
Thanks
Thanks
