Question about Asrock 4CoreDual-SATA2
12 May 2006
UK
Questions about Asrock 4CoreDual-SATA2
Hello!
http://www.overclockers.co.uk/showproduct.php?prodid=MB-011-AK
I was wondering if anyone that has used this motherboard knows whether it has that "Select Boot Device" menu option during POST that's built into the bios?, usually you have to press a serton keyboard key to get the menu to display so you can select what device you want to boot from. Most motherboard nowerdays, I think, has this option? My current very old Asus P4C800-E Deluxe motherboard has this option by pressing F8 during POST, witch I use for multi OS booting, without needing to change bios setting all the time, and need to know if this motherboard has this option too, because I really need it.
It states in the CPU Support List on there website that the board supports the Core 2 Quad Q6600(B3) 2.40GHz 1066MHz 8MB Kentsfield and so I was also wondering if this CPU below will work fine in the motherboard?
http://www.overclockers.co.uk/showproduct.php?prodid=CP-161-IN
Thank You!
I was also wondering what is the cheapest best quality NVIDIA PCI-Express Graphics Card that's just as fast as a GEFORCE 6800 Ultra 256MB or the best performer I can get that supports Dual dual-link capable DVI / DVI-D for use with those special LCD Monitors that require dual-link capability and has HDCP Enabled that should fully work with this Asrock 4CoreDual-SATA2 Motherboard without problems, and Its gotta be a NVIDIA PCI-Express Graphics Card that's around about 100 pounds or under?
