question about cleaning my keyboard
11 Jun 2006
Middlesborough
i have a wireless keyboard from the Logitech MX3000 Cordless Desktop set
does anyone know if its possible to remove the keys to clean under them? :confused:
edit: i just saw the topic as been moved so sorry for posting in the wrong section
i think ill pop em out :) i tried a air duster but they are thick with dirt between the keys and its quite disgusting :p
how long would i need to let it dry after that? :eek:
A week in the airing cupboard, even if you think it's dry, just leave it in there.
ps I take no responsibility in your own action :p mine was already covered in sticky coffee, giving it a bath of clean water is not exactly going to make the situation worse.
lol :)
well i only have one so i couldnt wait that long anyway ;)
i just tried removing one of the keys with a knife and it popped right off and on again :D its easier than i thought so problem solved, thanks for all the replies
just finished cleaning it now ;) ill get another one in a couple of years because this one is still working perfectly
im disgusted at the amount of crap that was under the keys :o
Back in the days of windows 3.1 my missus soaked her crucial MSc work floppy disc in milk. She discovered it a few days later, after the penicillin had started to grow.
I split the floppy case open with a razor blade (gillette, NOT a mach three), extracted the floppy bit, soaked it in warm water, ran the cold tap over it a few times, then dabbed dry on kitchen roll. Same with the stuff in the case. Over night in airing cupboard then reassembled and sellotaped. It worked fine and she got a distinction for her MSc.
Come to think of it I don't recall getting much thanks let alone a blowjob!
I got fed up cleaning my keyboards over the years so my solution was to simply buy a black one.
Can't see the dirt on it ;)
The last three I took apart and cleaned never worked after I put them back together again so now I just dont ....... ;)
RB
