Hi,
My main router is in the very left hand side of my house, I have ran a cat5 cable from the main router to a TP-Link TD5970 router and set it as a DHCP client so it receives its ip from the master router and sends out a second wireless signal which works fine.
My question is can i take another cat5 cable from the second router and run it to a third router and do the same thing as I need another wireless signal to reach a deadspot in the very far side of the house?
I know i could run a 2nd cable from the master router to the third router directly but this means using twice the amount of cable which would be a pain.
Thanks
Thanks
