Question about DVI to display port.
27 Jan 2015
Hello guys.
So I've got a BENQ XL2411z and the monitor has an HDMI, VGA and DVI port and I'm using a DVI port with my graphics card to get the 144hz.
However I've been looking to upgrade to a better GPU now, and I've found some GPU's that intrest me however they dont have DVI ports and they only support display ports or Hdmi ports, therefore I've been wondering if there any adaptors or such to allow me to go DVI from my monitor to the display port (1.4) in the GPU and have the 144hz.
Thank you.
You might get away with a good quality straight converter cable, but most likely you will want an active DP to DVI connector. @OcUK - PREDATOR is your man here. These are not cheap and you might be better off buying a new monitor and relegating the BENQ monitor to secondary use.
