I'm no good at electrical stuff so thought I'd ask this quick question!
I've got a device (USB Hub) that I need a new power adapter for, as the current one has too short of a wire attached. The current power adapter for the hub has an output of 5Volts and 4Amps.
I'm having difficulties finding a power adapter with exactly the same output, can I use a power adapter which has an output of say... 5Volts and 1Amp?
I'm also curious to know if it would be safe using a power adapter that gives an output of more Amps than required, say I had one that outputs 5V with 8A, would this cause any damage to the USB Hub? (I'm thinking along the lines of, the output Amps are an 'upto', i.e. upto 5Amps output? Or am I wrong in thinking this way?)
So, would I cause any damage, or what would be the affects of using a higher or lower Amps output than required?
p.s. I'm also curious, if anyone knows, how a power adapter can have an input of say xx Volts and 0.8Amps, then have a higher Amps output than the input? (Or does it just convert the V's to A's?
Probably a stupid question, but I had to ask. Found nothing on googles
)Probably a stupid question, but I had to ask. Found nothing on googles
