Question about Fan controllers.
9 Sep 2009
n00b question but how exactly do they work? I've never used a fan controller and want to try one out in a case with 4 Fans in. Do you just connect the fans up to the controller and the controller to the PSU or what?
enlighten me. :rolleyes:
I have one of the Zalman FSC which you connect to the psu molex and plug the 3 pin fans into the back. Adjust the fan speed which suits your need at the time.
Some controllers have sensors which can automatically adjust the fan speeds.
