My case is an Antec P182 fitted with 3 Noctua NF-P12 fans in the upper chamber (1 intake, 2 exhaust). CPU cooler is a Thermalright Ultra120 with 1 x Noctua NF-P12 fan pushing air through it.
Now i guess in it's current set up the air pressure is negative (more going out?) Also as all the fans are running at the same speed, there isn't going to be any turbulence, especially from the cooler to the rear exhaust fan.
Now my question is that if i were to change my CPU cooler fan to 2xAkasa Vipers, which run faster and push more air than the noctua's, would that have a negative impact on the air flow in the case?
should i just stick with all the same fans or those that push a similar amount of air?
Cheers
Cheers
