question about fans
10 Jul 2012
So where?
Hi all,
regarding any size fan the question is ;
If I cut off everything from the fan and leave just the fanblade motor and cable, would the 'performance' of the fan be affected significantly?
Does the fan housing act as a channel fkr the air?
You can assume I would ensure the fan was stable and well secured in situ.
The fans would be used to cool a radiator.
Thanks
Hi all,
Not by much I wouldn't have thought.
I suppose you'd get a little more leak to the sides.
If you've ever seen a video of a smoke test on standard PC fans you would not be too concerned about this loss.
cheers for that, you validated my own thoughts on the matter ;-)
