Question about gfx downclocking and SLI setups
24 Oct 2002
Portsmouth
Hi guys
It's a well known fact once you connect 2 monitors to a single Nvidia graphics card, the card runs at full clock speeds regardless of use and load.
However I was wondering. If you had two Nvidia graphics cards, and connected a monitor to each card would each card downclock to idle speeds on the desktop, or does that not happen either?
Just curious :)
Cheers
EDIT: Weird it is running full clocks with latest drivers - never used to with 19x.xx.
I'll test it later on tonight when I restart - my monitors are detected on the 1st GPU atm.
Having problems atm getting a 2nd display to even work on the 2nd card, even with SLI disabled it doesn't seem to be detected. I've not used it for anything other than SLI so I don't even know if the DVI ports are working lol.
Does this guide help? :)
An interesting post. What gets me is Nvidia says it cannot be done and it's a limitation of all graphics hardware... yet clearly it can as users are able to override the settings and lower the clock speeds without ill effects.
What that also confirms is a BIOS can be adjusted to make those savings. Anything that can be done in software can usually be done with NiBitor
Cheers all :)
