Question about higher FSB and lowering multis
19 Oct 2002
Torbay, Devon, UK
Hi
My current OC is 291x 11 = 3200 @ 1.48 vcore under prime
Now if I lower the multi nad increase the FSB to.
320 x 10 = 3200 will I need more vcore or will it work on the setting.
as I see people loweing thier multis to get higher clocks, (yes mine the same clock but its and example).
Regards
CV
The clock will be fine with same amount of vcore as before. The issue would be if your Northbridge couldn't handle the higher FSB. You may also see a performance increase with the added Bandwidth.
