- 25 Sep 2018
Hello everyone,
The time has come for me to consider upgrading my monitor. I currently have an ASUS ROG Swift PG258Q 1920x1080p with a TN panel and I am looking for a good 1440p panel to take advantage of my i7-9700k and my GTX 1080. I have seen these monitors which look interesting:
https://www.overclockers.co.uk/asus...descreen-led-monitor-black-red-mo-088-as.html
https://www.overclockers.co.uk/asus...n-led-slim-bezel-monitor-black-mo-099-as.html
They are identical apart from the first being an IPS panel and the latter a TN panel. My question is as follows: how noticeable would the difference in response times be between the two panel types? I believe IPS panels typically have a 4ms response time whereas TN panels have a 1ms response times. The games I tend to play most heavily are MMO's such as SWToR and strategy games like Total War, although I do occasionally play FPS's such as Battlefront and Battlefield.
Also, are all TN panels equal? I know IPS panels deliver better colour than TN panels, but, having come from a T.V. (with presumably an IPS panel), I've since adjusted to my current TN panel and I find the colours are fine. If the 1440p TN panel listed above would have near identical colour reproduction to my current TN panel that could be significant.
Last question: how significant is back-light-bleed on modern IPS panels? I know about the so-called panel lottery, but is this still an issue?
TLDR: How noticeable is the difference in response times between IPS and TN panels, would the 1440p TN panel give me identical or near-identical colours to my current TN panel, and how bad is back-light-bleed on modern panels?
Thanks!
Thanks!
