This is all the stats i could find, bearing in mind i have swaped routers in the last few days.
Modem Status
Connection Status Connected
Us Rate (Kbps) 448
Ds Rate (Kbps) 5376
US Margin 23
DS Margin 8
Modulation MMODE
LOS Errors 0
DS Line Attenuation 38
US Line Attenuation 46
Path Mode Interleaved
Transmit
Good Tx Frames 147824
Good Tx Broadcast Frames 249
Good Tx Multicast Frames 3914
Tx Total Bytes 59824728
Collisions 0
Error Frames 0
Carrier Sense Errors 0
Receive
Good Rx Frames 134615
Good Rx Broadcast Frames 257
Good Tx Multicast Frames 605
Rx Total Bytes 20367286
CRC Errors 0
Undersized Frames 0
Overruns 0
Valid Configuration Tree
Firewall NAT service started
USB interface is being brought up
Bridge Created: br0
USB Interface Successfully Brought Up
Bridge Interface Added: usbrndis
Bridge Interface Added: eth0
DSL Carrier is down
Bridge Interface Added: tiwlan0
DSL Carrier is up
pppd 2.4.1 started by root, uid 0
Connect: ppp0 {--}
local IP address
remote IP address
primary DNS address 195.92.195.91
secondary DNS address 195.92.195.90
PPPoA Connect with IP Address
PPPoA Connection Successfully Established
PPPoA Connect with Gateway IP Address
DSL Carrier is down
DSL Carrier is up
Connection terminated.
Connect: ppp0 {--}
local IP address
remote IP address
PPPoA Connect with Gateway IP Address:
primary DNS address 195.92.195.90
secondary DNS address 195.92.195.91
