question about ivybridge
29 Sep 2009
cheshire
im currently saving for a new gaming pc and wanted to know if anyone knows if ivybridge will be made for lga2011 boards that are out soon for the sandy bridge-e processors. (or will they use a new chipset and socket)
i was planning on saving until next year to buy a x79 motherboard with a sandybridge-e processor but all this talk of ivybridge being not far off has made me consider waiting. im not in a rush so it would give me more time to save.
many thanks
afaik ivybridge is not due til around April next year
This article talks about backward compatibility with Sand Bridge motherboards:
http://motherboardnews.com/2011/05/27/ivy-bridges-backwards-compatibility-explained/
Kinda confusing. It looks like if you have z68 you might be ok (but you'll be missing pcie 3 etc)
Imo just buy a 2500k with z68 right now if you have the money. They are pretty fantastic cpu's and from what I've heard 4ghz overclock and it still hasn't bothered to get out of bed yet :)
However if it's going to take you another 6 months to save, there's going to be a lot more solid info on Ivy Bridge then, so come back and ask when you have the money :p
Just buy now as there's no point in ever waiting given the speed hardware is moving at. By the time ivybridge is out, there'll be something else on the horizon.
Asrock have just released a set of z68 boards labelled 'gen3 that do support pci 3. You can stick a Sandy Bridge CPU in now and enjoy PCI 2 compatability, then put in an Ivy Bridge chip to access PCI 3.
thank you for the replys. think i will just carry on saving up and see whats available in the middle of next year.
ill have to just make do with buying skyrim on the xbox. :)
from what i read while ago on ivybridge is that q4 of 2011/q1 2012 low-mid end ivybridge chips will be released on socket 1155. then q2/q3 of 2012 the high end ivybridge is released on socket 2011. the ivybridge on socket 1155 should be backward compatibility with Sand Bridge motherboards, but that depends on the mobo maker most likely it be done by a bios firmware update.
many thanks
I imagine all LGA2011 processors will be 32nm which is basically what Ivy Bridge is, they'll probably have more cores and better memory controller but I shudder at the thought of the price.
If you're in no hurry to upgrade then it can't hurt to wait, but if you're expecting big things from Ivy then you're likely to be disappointed; it's just a die shrink of Sandy, don't expect big changes until Haswell arrives in 2013.
Ivybridge is 22nm isn't it?
Yes it is.
The newer chipsets supposedly launching with Ivybridge have native USB 3 though I can't see it being a huge difference from NEC's USB 3 Implementation.
Yes it is.
Pretty much, I swear I can't keep track of Intel codenames though, is Haswell right after Ivy, or the next but one, with Kessler in the middle?
EIther way, Sandy-e end of this year, 4-6 cores it seems 32nm, then Ivy on 22nm which has seemingly been pushed back to at least April, which will be current Sandy replacement, should almost certainly be same socket and mostly compatible with current boards is the general thinking on it.
Its mostly a die shrink, with improved IGP(IE 50% bigger IGP but realistically, still completely rubbish for gaming) but not a whole lot of other tweaks. Power usage is already pretty immense on Sandybridge's with proper power gating, so not sure Ivy will really drastically improve power usage for anyone, and while it might clock higher, most people going beyond 4Ghz on overclock are simply using more power, but not really getting any benefit so not sure how worthwhile that is right now.
The next architecture after ivy is said to be bringing 6-8 cores to mainstream, was aimed at late late 2012 but that was before Ivy was delayed by 4-6 months. From now that chip AFTER Ivy is the next really major improvement in Intel chips, I wouldn't wait 3 extra seconds for a Ivy over a Sandy, buy now and get more use out of it before Haswell, or if you've got a decent quad, just wait till you can get a quality 6/8 core without spending silly money on one.
Yeah, Haswell is the 22nm "tock" and actually looks pretty interesting;
http://www.xbitlabs.com/news/cpu/di...Instructions_to_Boost_Wide_Range_of_Apps.html
Ivy is less exciting to me although I will probably be looking to upgrade my laptop in the next year; if it runs significantly cooler than the AMD alternative it will most likely end up powering my new lappy.
