Hello.
A while back I bought a NVIDIA GeForce GTX 480M for my Laptop and I removed the
pre applied thermal paste and put my own on it.
I have noticed for ages that my temps have been quite high for this GPU on idle and load.
In the middle of the GPU heatsink there was a silver square part that looked like silver paper stuck to it.
When removing the pre applied thermal paste when I first installed the GPU, I actually removed silver square part
from the middle of the GPU heatsink because it peeled off easily enough after gripping a bit of the edge of it with
my nails and I thought this was also meant to come off too, thought it was part of the pre applied stuff.
I am now starting to wonder if that square silver part or whatever it is was actually not meant to be
taken off, the silver square part actually gives better contact between the heatsink and GPU and
helps disperse the heat better than the bare heatsink metal or etc.
Am I correct about this that this part was not actually to be taken off?
If this is correct then does anybody know what the silver square part is for and what's the that part called and
made of and where to buy the stuff or what I could put in the middle of the heatsink before re applying the
thermal paste that would do the same job just as efficiently as the silver stuff?
Thanks for responding.
