- 24 Oct 2009
Does a 220mm and 200mm case fan have the same distance between screws? I ask because the '220mm' on my fan isnt screw to screw, but the actual diameter of the fan. I wondered if '200' means the screw distance is the same, but the fan diameter smaller?
I wanted to get this case:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-188-CM&groupid=701&catid=7&subcat=
and put a 220mm fan on it? But it says 200mm fan
