Hey guys
I have a following problem:
I am planing a Corsair 540 mod with 1080 Phobya rad.
I'd like top put it on the right side, outside, in the special 'case' (made by Phobya as well).
The problem is, if I cut the window in the right panel there wont be much left of it (maybe 15-20mm and huge hole in the middle), so I don't think this will have actual strength to hold the rad in place.
So my question is, do I actually need to cut the hole at all?
Or is it enough to just screw the radiator box to the right panel and direct airflow outside, so air isn't blowing into solid wall?
Why do I want to use that rad at all, well, I thought this was a big case and I was planning to use it to make a killer build over time, with 4 gpu's, solid tube watercooling etc, but I realized that it can only take 2 280 rads inside or 280 + 360 if I put fans outside the case + 180 (2x90) rad above the PSU if I remove the SSD cage. And thats absolutely not enough for cooling oc'ed 4770k and 4 high end gpu's.
Thats why I thought about the 1080 Probya, rad, it could probably handle 2 or even 3 gpu's and the rest would be easy.
Anyway, if you know answer to my question, please let me know
Thanks
Thanks
