question about lian li V1000+II
Should fit!
Here's my PC-101B which is identical to the V1000 inside:
As rpstewart says you'll lose a HDD bay.
If you have more than 3 HDD's you could fit a couple in the optical bays above though so don't worry!
gt
Bloody hell thats some extreme fan/cooling going on.
Whats the CPU Cooler like and does the PC101 help keep everything quiet?
Hi RC21,
The Titan's a pretty good cooler (but not amazing - water still beats it). Probably would be better if i was a little braver when it comes to mounting it. Just didn't wanna crush my 680i! :p
On the 101 front i had an Antec P180 before this and the difference is night and day. Firstly, the Antec is not a quiet case in my experience. Secondly, the 101 has exquisite build quality and is a dream to work in. It's quiet and good looking too! Most definately an excellent case that i'd recommend to anyone. As such i'd also recommend the V1000 for the same reasons! ;)
Lovely case and on top of this it could happily support SLi GTX's and an Enermax Galaxy in what is a nice compact enclosure.
gt
I can get an Enermax Galaxy 850 in my Lian-Li V1000B+ so I guess you should to aslong as you can take the second HD rack out as shown above.
