Question about LinX 0.6.4
19 Aug 2011
I read that if my overclock passes 50 tests within LinX 0.6.4 It can be considered stable. my 3570k passed with an OC of x44 here:
Intel(R) LINPACK 64-bit data - LinX 0.6.4
Current date/time: Wed Dec 05 12:43:36 2012
CPU frequency: 4.392 GHz
Number of CPUs: 1
Number of cores: 4
Number of threads: 4
Parameters are set to:
Number of tests : 1
Number of equations to solve (problem size) : 10004
Leading dimension of array : 10008
Number of trials to run : 50
Data alignment value (in Kbytes) : 4
Maximum memory requested that can be used = 801164512, at the size = 10004
============= Timing linear equation system solver =================
Size LDA Align. Time(s) GFlops Residual Residual(norm)
10004 10008 4 5.932 112.5618 9.850637e-011 3.471222e-002
10004 10008 4 5.864 113.8499 9.850637e-011 3.471222e-002
10004 10008 4 5.868 113.7754 9.850637e-011 3.471222e-002
10004 10008 4 5.869 113.7662 9.850637e-011 3.471222e-002
10004 10008 4 5.867 113.8010 9.850637e-011 3.471222e-002
10004 10008 4 5.860 113.9419 9.850637e-011 3.471222e-002
10004 10008 4 5.867 113.8021 9.850637e-011 3.471222e-002
10004 10008 4 5.895 113.2575 9.850637e-011 3.471222e-002
10004 10008 4 5.873 113.6889 9.850637e-011 3.471222e-002
10004 10008 4 5.869 113.7646 9.850637e-011 3.471222e-002
10004 10008 4 5.859 113.9511 9.850637e-011 3.471222e-002
10004 10008 4 5.872 113.7102 9.850637e-011 3.471222e-002
10004 10008 4 5.863 113.8704 9.850637e-011 3.471222e-002
10004 10008 4 5.864 113.8676 9.850637e-011 3.471222e-002
10004 10008 4 5.867 113.7975 9.850637e-011 3.471222e-002
10004 10008 4 5.869 113.7615 9.850637e-011 3.471222e-002
10004 10008 4 5.870 113.7367 9.850637e-011 3.471222e-002
10004 10008 4 5.867 113.7952 9.850637e-011 3.471222e-002
10004 10008 4 5.862 113.9046 9.850637e-011 3.471222e-002
10004 10008 4 5.863 113.8705 9.850637e-011 3.471222e-002
10004 10008 4 5.876 113.6268 9.850637e-011 3.471222e-002
10004 10008 4 5.865 113.8338 9.850637e-011 3.471222e-002
10004 10008 4 5.875 113.6474 9.850637e-011 3.471222e-002
10004 10008 4 5.881 113.5300 9.850637e-011 3.471222e-002
10004 10008 4 5.871 113.7166 9.850637e-011 3.471222e-002
10004 10008 4 5.867 113.8069 9.850637e-011 3.471222e-002
10004 10008 4 5.879 113.5593 9.850637e-011 3.471222e-002
10004 10008 4 5.880 113.5393 9.850637e-011 3.471222e-002
10004 10008 4 5.882 113.5176 9.850637e-011 3.471222e-002
10004 10008 4 5.891 113.3330 9.850637e-011 3.471222e-002
10004 10008 4 5.882 113.5035 9.850637e-011 3.471222e-002
10004 10008 4 5.877 113.6086 9.850637e-011 3.471222e-002
10004 10008 4 5.879 113.5760 9.850637e-011 3.471222e-002
10004 10008 4 5.884 113.4667 9.850637e-011 3.471222e-002
10004 10008 4 5.872 113.6985 9.850637e-011 3.471222e-002
10004 10008 4 5.880 113.5540 9.850637e-011 3.471222e-002
10004 10008 4 5.882 113.5089 9.850637e-011 3.471222e-002
10004 10008 4 5.879 113.5719 9.850637e-011 3.471222e-002
10004 10008 4 5.876 113.6190 9.850637e-011 3.471222e-002
10004 10008 4 5.883 113.4833 9.850637e-011 3.471222e-002
10004 10008 4 5.878 113.5889 9.850637e-011 3.471222e-002
10004 10008 4 5.884 113.4708 9.850637e-011 3.471222e-002
10004 10008 4 5.892 113.3245 9.850637e-011 3.471222e-002
10004 10008 4 5.880 113.5486 9.850637e-011 3.471222e-002
10004 10008 4 5.876 113.6178 9.850637e-011 3.471222e-002
10004 10008 4 5.880 113.5399 9.850637e-011 3.471222e-002
10004 10008 4 5.876 113.6302 9.850637e-011 3.471222e-002
10004 10008 4 5.881 113.5364 9.850637e-011 3.471222e-002
10004 10008 4 5.882 113.5146 9.850637e-011 3.471222e-002
Performance Summary (GFlops)
Size LDA Align. Average Maximal
10004 10008 4 113.6301 113.9511
End of tests
Should I test with anything else (i.e Prime95) or just leave it for granted that it's stable :confused:
