- 25 Jun 2005
When our kitchen was done out it transpires that the ceiling never had a mist coat applied.
Cue 5 years later, it's a flaky mess. The plasterer I use has actually re-boarded the ceiling and skimmed it and it's now ready to paint.
I intend to do a 50/50 mist coat, then 2 (or 3 depending on how 2 looks) coats of proper kitchen matt emulsion. Question is this - does the mist coat need to be kitchen paint or will "normal" emulsion be ok?
The top coats will be done in proper kitchen paint, I just haven't bought it yet. Only reason I ask if I have loads of white emulsion left from decorating our dining room last month.
Cheers
Cheers
