Question about moving from HD to SSD and data transfer
2 May 2014
Manchester
I'm looking to rebuild my PC with a new Motherboard, SSD etc as per my thread in the Hardware area
I have a question though that relates to my current hard drive
My Current 180gb hard drive has my games / office . music etc on it. Ideally I want to keep these and use this drive as a storage unit and put the games and the new OS on a SSD
But how do I go about this? I'm pretty much a newbie at this stuff so as simple as possiable would help
It's currently partioned as well which I don't mind to be fair but I want to keep some stuff thats there but not everything as stated above
NB - if it helps I'm looking at the HyperX 250gb SSD with 8GB or ram bundle for my rebuild
Great Guide - almost what I'm after.
My Issue is the OS side of things - How do you over come this?
Cause I don't want the 32bit os I currently have as I am going to have a fresh 64bit os install on the system?
ahh you'd need to do a clean install then on your new ssd
keep your old hdd as it is and decide what to keep/delete off it later
How do I remove the old OS / extra crap thats there?
There is a lot of stuff I want to keep - but I'm not 100% sure were it is on the drive as such
For example, due to space issues and the rubbish that was on the machine when I got it I have World of Tanks on side of the partition, and War thunder on the other side
My main C drive basically is almot full - I think around 5-7gb free, while the other side has about 15gb free
I Barring the OS + the other rubbish that was there already, I want to keep every thing else - Games / OS and Office on the SSD (Hence going for the 250gb version so it has more then enough space) with music, documents and other unimportant stuff on the HD
