- 9 Mar 2009
- Newcastle
Hi guys,
I'm about to build my first PC and have the components on order. I was on a bit of a budget so went with some mid range stuff with the plann of slowly upgrading over time.
I bought the Abit IP35 Pro XE Intel P35 (Socket 775) PCI-Express DDR2 Motherboard and I do get the impression that it is a very good motherboard with good overclock potential. My only question really is the fact that it is only DDR2 compatible. This obviously isn't a problem at the minute but is this going to be a problem in the near future? Is DDR2 being phased out for DDR3? or should I be alright for now? Obviously it's not a major problem as I can just upgrade it at some point if necessary, but i am going to be running 4gig DDR2 ram on it which i would like to increase at some point, so I just wanted to know whether it's going to be a problem pretty soon or if i will be fine for at least a few years yet.
Thanks guys
Bob
Thanks guys
Bob
