Question about my radiator fans
29 Nov 2017
Hi guys.
A penny for your thoughts :)
I'm running with two radiators with 3 Corsair Air Series SP140 LED on each and i think it's maybe time for a fan upgrade. Did not much reading back then when i bought those fans, and it looks like, today that there's much better fans for radiators.
So a couple questions
*Which fans should i go for? Cheaper is better and it has to be some kind of LED/RGB. The radiators are two old Alphacool NexXxoS UT60 420
*I have a bunch of Yate Loon fans just laying around. Could i use them as "pull" or is it just stupid to use two different brands/fans on a push/pull config?
I don't know of any really good LED/RGB fans. You could use Phanteks Halos
https://www.overclockers.co.uk/search?sSearch=phanteks+halos
The best fans are be quiet! Silent Wings 3 140mm PWM High Speed, but they are also quite expensive.
https://www.overclockers.co.uk/search?sSearch=silent+wings+3+pwm+140mm+high+speed
Best lowest priced fans are Arctic P140 series available in packs of 5 for 24 quid variable voltage and 30 quid PWM, but OcUK doesn't have any. While they are not the best they are good low cost fan.
