Beyond3D said:Enhance the application setting works in conjunction with the application and its request for AA, so that the driver can see how it performs its regular AA to see if CSAA can be further applied in conjunction. You set a chosen CSAA mode in the driver and turn on AA in your app too for that setting to work. It's not too clear why the non-CSAA modes are still available as choices with Enhance the application setting, though.
No, if you select Enhance the application and select 8xCSAA in the Nvidia control panel you get 8xCSAA as long as you enabled AA in the game.Gerard said:Just wondering about this "enhance the app aa setting" option, say i have 4x selected in game and i have enhance set to 4x, does this give me 8x in game?![]()
so what's the difference between override and enhance? Surely they both have the same effect, using the nvidia setting instead of the in-game settingDutch Guy said:No, if you select Enhance the application and select 8xCSAA in the Nvidia control panel you get 8xCSAA as long as you enabled AA in the game.
zytok said:so what's the difference between override and enhance? Surely they both have the same effect, using the nvidia setting instead of the in-game setting![]()
Override can be used if the game does not have an AA setting in the game, enhance needs the game to have an AA setting.zytok said:so what's the difference between override and enhance? Surely they both have the same effect, using the nvidia setting instead of the in-game setting![]()
So again, what's the point of having both options? If you're not using the ingame settings, then why not just have an override option?Dutch Guy said:Override can be used if the game does not have an AA setting in the game, enhance needs the game to have an AA setting.
get busy reducing your sig size you waster.....StevieP said:Busy Zytok??![]()
