Question about ObjectDock.
27 May 2007
Front of the monitor
Hi all,
For those that is using ObjectDock, is it possible to get the dock in such way that when you click on an icon it shows a folder with more program or like a string with programs? I seen something similar ages ago in the Desktop thread but can't remember where in the thread (or even if it was ObjectDock or another Dock program!)
Not sure if I have explained it good enough but hopefully someone of you will understand what it is I am after.. if not I guess i have to start sorting through all the thousands posts in the DeskTop thread.. :o
Any and all help will be greatly appreciated!
pretty sure the stacks addon works on object dock too, no need to change to rocket dock
Yup, its working fine on ObjectDock as well, thank you to the both of you! :)
Another question though.. Can someone recommend a place where you can get some good icons for it, or is it hard to do your own icons? If its not, what program should you be using to make them, don't have PhotoShop so has to be a free program preferably!
