Question about onboard SPDIF / transport to a DAC
15 Sep 2006
Liverpool
Hey guys
Just a quick question. I've just bought a new DAC, which is going to be the source in my headphones setup. The DAC's only inputs are SPDIF (optical and coaxial). Now, my motherboard has onboard digital outputs of both kinds, but I'm always hearing how bad the quality is from them. So I was wondering, what would be the best way to get around this? I've got about £20 to spend.
Should I get a sound card with digital outputs? For about £20 I could probably get a cheap Soundblaster - the question is, would it output higher quality than my motherboards SPDIF output? Also, if you search the popular auction site for "usb to spdif" there are a couple of adapters from Hong Kong, does anyone know if they'd do a good job or not?
Thanks for any input.
Depends how stable the clock is, ideally you'd get a sound card you can slave to the clock in your DAC
You can get interference on digital signals - it manifests itself as jitter - usually inaudibly.
I specifically avoided mention of jitter, that's for people with too much time on their hands since it is completely inaudible in even the worst of cases.
So erm, should I get a sound card or not?
Bare in mind my headphones are pretty transparent and would most likely reveal flaws in a system. I have Sennheiser HD650s.
If you're going to buy a soundcard, only do it if you can lock the clock on it to that on your DAC, i don't know the make/model of your DAC to be able to tell you if it has that feature.
It's not going to be cheap, so use the onboard for now and see what you think.
Not sure what you mean by that.
This is the DAC I have.
No it's not, it drastically reduces the width of the stereo image and the depth of the sound - you don't hear jitter per se but you can definatly tell the difference with and without it.
"width of the stereo image and depth of the sound" - don't throw around silly phrases from a stereophiles magazine, its affect on the waveform is not that. I've yet to see a double blind or any other test where the affects have been audible unless artifically introduced.
Ignore it, trust me, it's very much along the lines of thousands on speaker cable and power leads. I own HD650's myself.
Obviously you don't have a clue what you're talking about if you think i get phrases from audiophile magazines - i have sat and i have heard the difference it makes myself, i can also hear the difference on small capacitor change on a tweeter crossover makes - that was some testing i did for a research company.
That DAC doesn't appear to support external clock anyway, i was assuming since it was a standalone DAC it would be somthing more fully featured, that's just a digital headphone amp to me.
It's only a £60 DAC. It has a headphone amp and pre-amp built in as well yeah. I won't be using them though, I have a separate headphone amp.
Apparently it's the best DAC in the price range though.
I presume all this was done double blind, and can you upload the results of your testing?
No, it's commercially sensitive and it was done in the lab.
On a £60 DAC you won't be able to tell, i was assuming the OP was spending upwards of £1,000 as thats generally where standalone DACs start being worth it, this is nothing more than a digital headphone amp.
It's a DAC with a headphone amp. If it was just a "digital headphone amp" then it wouldn't have the feature to bypass the amp and use it as a standalone DAC. Unless I'm missing something...
I think I'm going to take AbsenceJam's advice this time mate. He seems to be a bit more realistic about it.
Bypassing the headphone amp is very simple, they've just stuck it in as an additional selling point.
Really you'd have been better off getting a soundcard with a higher quality analog output stage and feeding that into your own headphone amp.
