When applying for a mortgage is it a good idea to close any credit cards etc etc you may have on file buy don't use, or to keep them open, same with overdrafts?
For example:
Using online banking I can instantly get:
£3,800 Overdraft
£5,500 Limit on Halifax Card
£5,500 Egg Card
Now would it be wise to max out the available credit limits, however not spend, showing I have x amount available however not used.
Or would it be best to have £0 overdrafts and to close all CC and to start from scratch?
Cheers
For example:
£3,800 Overdraft
£5,500 Egg Card
Cheers
