Question about performance vs the capacity of each DDR3 RAM module (3-channel mode)
17 Apr 2006
3rd rock...
Hey guys coud you gimme some advice on this? I dont really get it. Please tolerate the diagrams :D as I needed to make this clear heh.
I wanna chuck 6GB RAM into my system. There are 6 DDR3 RAM slots on the mobo.
I've been reading the manual for my motherboard (see spec below) and in the section about fitting RAM it says:
Three-Channel Mode (TCM)
In TCM the memory modules transmit and recieve data with three data bus lines simultaneously. Enabling TCM can enhance the BEST system performance. When you have 3 or more memory modules please insert them as shown below to get the BEST system performance
[---------------------] = empty slot
[|||||||||||||||||||||] = used slot
3 Modules
4 Modules
5 Modules
6 Modules
Ok heres my question - am I right in saying that I will get better performance if I buy 6 X 1GB sticks of RAM?
And that performance will be slightly lower if I get 3 X 2GB sticks?
Im not cued up on this channel-stuff :confused:
Thanks ;)
No - memory performance will be identical with 3x2GB compared to 6x1GB (assuming the modules are the same frequency and timings).
However, with 6 modules installed you will be putting much more strain on the memory controller on the i7 CPU - so overclocking will be trickier and you won't be able to go as high.
Thanks for clearing that up mate :D I understand whats happening now. Its not the capacity of the modules but adherence to which SLOT you use when you have 3 or more modules. This wont maximize performance.
Ive decided to go for 3 X 2GB :o
