- 5 Nov 2004
So I want to set up a downloading client to use a specific port and I just want to try and understand this
On my router under services it gives me these options
Name
Type
Start port
Finish port
So in my name I put my identifier which I assume makes no affect to anything you do.
Type I choose TCP/UDP
now with ports if I wanted to open say 6001 do I put it like this
A:
Start - 6001
Finish - 6001
or
B:
Start - 6000
Finish - 6002
I assume its example A:
Also, If I wanted to open a range of ports from say 6000 to 6010 I take it I just set it up as
Start - 6000
Finish - 6010
I know it seems very simple but when you are trying to get things working perfectly and your a little thick to networking it can end up being a long process.
Do I then go into my routers firewall option and then allow this port in both the inbound and outbound fields?
Do I also have to disable uPnP on the router??
Name
Type
Start port
Finish port
A:
Start - 6001
Finish - 6001
or
B:
Start - 6000
Finish - 6002
Start - 6000
Finish - 6010
