Permabanned
- 4 Sep 2011
- Durham
In my 780t Corsair case, I have two of the 140mm Corsair magnetic fans in the front in a pull configuration and two of the same fans on the roof,also set to pull ,connected to my H110i GTX. I have a single 120mm Corsair fan set to pull on the rear of the case as well but its not the same as the other four fans I am using. Would I be correct i thinking it would be just as effective to only use the two at the front and the two on top and do away with the one at the rear? My thinking is that its pulling air in the front and up through the rad and out the top of the case and that the single fan on the rear is disrupting the flow that those four fans create?
If "heat rises" is wrong then so is "heat radiates". It's true to say that heat does not rise, hot air rises but then heat does not radiate, matter absorbs and emits electromagnetic radiation. Conduction and radiation are processes by which heat is transferred, not heat itself. But honestly most people say heat rises so in my mind that just fine. It's not exact, but we get the idea. Well, most of us do.
And in fact heat removal in a PC is by conduction not emission.
