- 14 Jun 2011
- Wolverhampton
Hi guys
Got a couple of MSI 970s on the way, never had SLI before so want to check which way is best to power or if it even matters?
I have a Seasonic 860W platinum PSU
Can I have one splitter cable that has 2 6+2 ends going into both cards on the 8 pin inputs then another cable with 2 6+2 ends going into both 6 pin inputs?
Or is it better to have one cable per card so one cable with the 8 and the 6 being used?
I ask because the way the cable is made it will look neater if the cables are powering 2 cards because of how the splitter bends like an SLI bridge.
Hope this makes sense.
Thanks
Thanks
