- 8 Apr 2004
Question about powerline for additional rooms
Hi all, I've been reading about powerline adapters recently as I've noticed I get only half the speed via WiFi connection compared to ethernet, even when in the same room as the HH3 router from BT Infinity.
I would like to move the router from downstairs to my room so I can just RJ45 it to my PC, but now I'm considering buying a pair of the TP-Link 200Mbps adapters. Now should this go well, how do I connect each PC in the other two bedrooms upstairs? Do I need to buy another 2 pairs or just a single one for each room? If I connect my PC via powerline to LAN port 1, then wouldn't the other 2 PCs need their own powerline in LAN ports 2 and 3 so they get their own IP addresses?
I hope it's not more pairs cos can you imagine having 3 sockets near the router taken up just for powerline lol. Still going to be using WiFi for our mobiles, laptops and tablets, but we mostly spend our time online on our desktop PCs streaming video, so having full speed is a must without having to route 3 separate RJ45 cables from the router downstairs.
If only one per room is needed, could I buy a pair and use them individually? Then I would end up with 1 connected to my router downstairs, and 3 single ones, one in each room upstairs. I see that buying a pair is cheaper than buying 2 single ones.
Thanks in advance.
Thanks in advance.
