I recently purchased 2 arctic pwm fans for my eclipse 62,
http://www.overclockers.co.uk/showp...ing Arctic Fan 12025PWM 120mm Fan - 4-Pin PWM.
Ive also got a TRUE120 and two scythe s flex 1200rpm fans on the way. Im thinking of using the scythe fans on the case itself and putting the arctic fans on the cooler in a push pull config. My main concern is if it will be ok to daisy chain the two pwm fans and run them of the cpu fan header. Thanks in advance.
