At the moment, I have a broadband modem, supplied by Telewest, which plugs straight into my computer (Running Linux) via an Ethernet cable. I soon plan on getting a laptop, and I intend to share this internet connection with it, wirelessly. I dont want to have to install a wireless card into my pc. Is it possible to plug the modem into the router, and then plug the router into the pc, still via an ethernet cable (so that I can carry on using the internet on my pc as normal, without changing any settings)? What kind of router can someone reccomend for this? Also, will this kind of setup mean that my PC has to be on for the wireless network to run?
Also, how do you go about encrypting the wireless network, so that it is not open to others. Does every router come with this supported?
