Question about side panels ? (Stupid)
17 Sep 2007
West Yorkshire / Market Bosworth
okay i have a apevia x cruiser case in black. and i was wandering if i had to find a replacement say if the acrylic broke or something as it does seem to be very delicate do i have to find another apevia x cruiser side panel or is there a universal sort of fitting for this sorta thing ... like so, will others fit on the case even if its not specifically designed for my exact case.
You may get lucky and find a panel that "just happens" to fit your case but it's more than likely you'll need a replacement from the manufacturer/shop. :)
