Question about significant figures
Caporegime
24 Oct 2012
Yer nan's knickers
I understand how these work but one thing I am struggling to get my head around: if asked to calculate something and round it off to 2sf, when do I round? Do I calculate all the equations and then round off, or round off first and then calculate?
Help pls, head maek expload :(
EDIT: Here's the actual question:
"Resistors R2, R3, and R4 could be replaced by a single resistor. What would be the value of that single resistor? Give your answer to 2 significant figures."
I've got it all worked out but rounding before or after the calcs gives two different answers.
generally a good idea to maintain as much precision as is feasible within calculations and then round the result
That's exactly what I do with mine. It's amazing how far something can get thrown out by over a decent length calc just by rounding early.
This is the question for those interested:
My answer is R=0.64Ω
Dunno if it's correct or not but as according to my username, this paper is due at midnight and I've still got a bit to do :rolleyes:
I don't think r=0.64 can be right... there's essentially two parallel resistances: 27Ω (R2+R3) and 18Ω (R4). 0.64Ω is far too low....
You're right, I took R2 and R3 as being on a different line altogether, when they simply need to be added up. What an idiot :rolleyes:
What us going on here?
R2 and R3 in series, 15 + 12 = 27 ohms
And This 27 ohm is in parallel with R4
So, 1/27 + 1/18 = 1/R,
R = 35.18 ohms = 35 ohms (2 sig fig)
You need not consider R1, as it was not asked about.
Nope the answer is 10.8ohms. Remember in parallel the total resistance will.always be lower than the lowest parallel resistor.
There's the quick and dirty method too when only dealing with two resistors in parallel:
27*18 / 27+18 = 486/45 = 10.8ohms
The long way would be:
1/27 + 1/18 (lowest common denominator is 54) so 5/54 is 10.8ohms
Resistance questions are generally straightforward, but here is a teaser.
A lamp and three identical resistors form a circuit as shown below. The lamp is shining brightly. A fourth identical resistor is added to the circuit in such a way that the lamp goes off (no current in lamp).
Where should this extra resistor be inserted?
